Interchangeability PCM ˋ96 - ˋ97
Old Oct 29, 2021 | 03:21 PM
swisscheese's Avatar
Are the two modelyears PCM interchangeable?
both are from an automatic car
Old Oct 29, 2021 | 04:08 PM
RUDEDOG's Avatar
Re: Interchangeability PCM ˋ96 - ˋ97
Yes
Old Oct 31, 2021 | 12:00 PM
ok, thanks
Old Nov 3, 2021 | 03:10 AM
comes to mind:
How about the different dashboard from '96 to '97. Do the gauges still read correctly?
Old Nov 7, 2021 | 10:55 AM
hotrod18_69's Avatar
Yes sir they do.
Old Nov 7, 2021 | 09:09 PM
Only the tachometer and the speedometer/odometer are driven by the PCM. The gauges are wired to the appropriate sensor (oil, coolant, fuel), or circuit (volts).
Old Nov 8, 2021 | 01:18 AM
Thanks!
The reason why I wan't to know for sure is that I wanted to buy a PCM from a '96 for my '97 and have it programmed right in the US and then have it shipped to my place over the pond. It would be bad if the PCM arrives at my place and it wouldn't work in the end.
Old Nov 8, 2021 | 10:36 AM
To ensure the speedometer/odometer is calibrated correctly, you need to tell the programmer your rear axle ratio and tire diameter.
Old Nov 9, 2021 | 01:26 AM
Good point! where there different axle ratios on the automatics?
btw. Solomon is taking care of it. Curious about the changes. Hopefully I get the PCM soon...
Old Nov 9, 2021 | 09:00 AM
The A4 cars had either a 2.73:1 rear axle (base, RPO code GU2), or 3.23:1 (performance axle GU5).
Stock tire sizes were either 235/55-16 (26.18”) or 245/50-16 (25.65”). SS coupe option tires were 275/45-17 (25.66”)..
Old Dec 3, 2021 | 06:43 AM
Got the PCM last friday and installed it on sunday.
Test drive was fine without any problems!
Next thing I have to do: buy block off plates for the EGR...
daddyoisback
Parts Wanted
Jun 10, 2012 10:43 PM
ENRKyle20
Jul 7, 2009 12:59 AM
vonmoldy
Sep 1, 2004 09:30 PM
Supermanx500
Apr 12, 2004 06:43 PM
Rodrigues
Mar 16, 2003 03:54 PM
