intake question, (lt4)
Old Apr 27, 2003 | 05:04 PM
hot936spd's Avatar
i have a 93 z 28 would an regular lt4 intake fit on a 93 . if so would i have to get it ported before i got a 58 mm throttle body on it. or just leave it? thanks
Old Apr 28, 2003 | 07:34 PM
arnie's Avatar
The LT4 intake will not fit on LT1 heads without machining the manifold mtg. surface of the head higher (closer to v. cover mtg. surface), or maching off the extra as cast material above the port (at the flange) on the LT4 intake manifold. The LT4 intake is cast with more material above the port roof (at the port flange). As cast, the LT1 and LT4 intake port size is very similar, but cuz of the additional material available for porting, the LT4 intake port roof can be raised a greater amount than the LT1 intake is capable of. The TB openings on the LT4 are the same as the LT1. (52mm)
LeftoverChinese
Jan 14, 2024 03:03 PM
MadMav
Feb 6, 2015 11:02 PM
ModdedNerd
Jan 29, 2015 07:23 PM
95chwagon
Jan 13, 2015 09:19 PM
