Intake Manifold question
Old May 7, 2009 | 12:55 PM
josh77888's Avatar
Exclamation Intake Manifold question
is the intake manifold on a 93 different then a 94 and up?
found one that is ported to a 58 and its a steal at the price, so i was a little curious if it will match up before i buy it.
Old May 7, 2009 | 02:08 PM
SnakeOiler's Avatar
Yes, there are design differences
Old May 7, 2009 | 04:19 PM
josh77888's Avatar
let me reword my question, am i able to use it on my 93z if its off a different year?
Old May 7, 2009 | 06:38 PM
bw_hunter's Avatar
The later manifolds will bold on but the fuel rail connections are in a different spot and the later fuel rails are different as well. There really any advantage to switching to a later manifold as you can easily port yours to 58mm. I used a 1-1/2" drum sanding roll in a dremel tool and it probably didn't take 2 hours.
Old May 7, 2009 | 10:45 PM
josh77888's Avatar
what kind of HP gains will i be looking at with a 58m intake and 58m TB, ive heard 10rwhp on just the TB alone but didnt know if it was true?
Old May 7, 2009 | 11:41 PM
BCdawg57's Avatar
unless you are pushing 400 hp you will see little to no gains with a 58mm tb.
Old May 7, 2009 | 11:49 PM
sbs's Avatar
sbs
Yes. Straight swap.
Noer
Feb 28, 2015 11:29 AM
CARiD
Jan 27, 2015 06:27 AM
ModdedNerd
Dec 14, 2014 10:28 AM
Elcojoe
Nov 17, 2014 10:27 PM
Jul 4, 2005 05:00 PM
