Intake Manifold Question
Old Feb 23, 2004 | 10:58 AM
97WS6SCharged's Avatar
Hey guys,
I'm getting ready to go pull my intake so I can fix the notorious manifold leak (wish me luck). Anyway, I don't have a torque wrench that reads in lb/in. Here's my question, if I use my regular torque wrench to initially tighten the bolts, what should I tighten them to? I'm thinking like lowest setting on the wrench (10 lb) would work. Any other suggestions (besides going to buy a lb/in torque wrench) would be greatly appreciated. I know that the final torque should be 35 lb/ft.
Thanks all
Old Feb 23, 2004 | 11:32 AM
Gripenfelter's Avatar
You need ft/lb not ft/in as far as I know.
I've done it on 3 cars with no problems.
Old Feb 23, 2004 | 11:51 AM
12 lb. in. = 1 lb. ft., so 6 lb. ft. would be good for the first pass.
Old Feb 23, 2004 | 12:56 PM
LT1TONY's Avatar
Make sure you start from the middle intake bolts and work your way out too the end when torqueing.
Old Feb 23, 2004 | 01:40 PM
Thanks guys. I just got done pulling my fuel rails and TB and I noticed the inside of the manifold is dripping wet with gas. I think that my fuel pressure regulator is busted cause when I layed the rails down, the AFPR began leaking where the vacuum line from the manifold plugs into it. Also, I checked the intake all around with a mirror and flash light and I can't find any leaks (guess I lucked out huh). Looks like Aeromotive is going to give me a new regulator.
Thanks again guys.
Old Feb 23, 2004 | 02:32 PM
ledfootz28's Avatar
when i had my car on the lift i noticed oil driping down the drivers side to the bottom of the tranny pan.im just guessing its either the manifold or the oil pressure sending unit.so i got my new sending unit from cromer the other day and intake man gaskets and am going to tackel the job in a couple weeks.
Old Feb 23, 2004 | 02:35 PM
Good luck with it. I thought mine was going out cause the idle has gotten progressively crappier and I keep smelling gas when I try to start it. Guess I'm just smelling gas that's seeping around the AFPR. Oh well, a new one will be here tomorrow afternoon.
Old Feb 23, 2004 | 03:05 PM
KyleBlue85Iroc-Z's Avatar
Wow, you're the first other person I've heard about with this problem. My old '85 Iroc had TPI and has the same type fuel reg. as LT1's. I had starting problems and a backfire issue with it and couldn't figure out what was wrong. I started pulling hoses and stuff to find out what was going wrong and when I pulled the hose to the FPR it shot out gas!!! Ended up the diaphram inside it somehow just deteriorated and I had the same fuel sitting in the manifold as you have! We're both lucky nothing ever caught fire.
Good luck with the fix. I did my manifold leak about 6 months ago (along with pressure sender) and I still get a drop or two randomly, but it's not "pouring" like it was before. The best advice I can give you is be very patient with the RTV beads you run, those are the most important! I've got a pic from mine here: http://community.webshots.com/photo/...91603412aTjZee
Good luck.
Kyle
Noer
Feb 28, 2015 11:29 AM
CARiD
Jan 27, 2015 06:27 AM
ModdedNerd
Dec 14, 2014 10:28 AM
Elcojoe
Nov 17, 2014 10:27 PM
Jul 4, 2005 05:00 PM
