Intake manifold install
Old Jul 1, 2008 | 08:20 AM
silver95's Avatar
When screwing the vacume connectors into the intake manifold should I use a sealant on the threads? What kind of sealant would you suggest? Also on the water pump when installing it what kind of sealant would you use here. I figured that since the opti sets right underneath the water pump that you would use a sealant with the gaskets to make sure that there were no leaks. I sound like a newby. I use to work on my own cars when I was younger and I new all of these answers. I hate getting older.
Old Jul 1, 2008 | 08:28 AM
Teflon tape or thread sealant/pipe dope on the vacuum fittings. Water pump gaskets can be installed dry or with a very thin film of RTV (helps hold them in place). Thread sealant on the w/p bolts.
Old Jul 1, 2008 | 08:30 AM
ZL1modified's Avatar
permatex- the right stuff for waterpump gaskets and teflon tape for threads on intake vacuum lines...
Old Jul 1, 2008 | 09:48 AM
silver95's Avatar
Thanks for the info.
Noer
Feb 28, 2015 11:29 AM
CARiD
Jan 27, 2015 06:27 AM
Elcojoe
Nov 17, 2014 10:27 PM
Snoman73
Nov 17, 2014 07:22 PM
Jul 4, 2005 05:00 PM
