Intake manifold gaskets, or RTV?
Old Apr 3, 2010 | 03:09 AM
MikeGyver's Avatar
My block and heads have been decked so the intake manifold probably needs to be milled, (more milling is required the thicker the intake gaskets are).
Is there any reason I can't use RTV instead of a intake manifold gasket on my (turbo'd) LT4 heads/intake? No reason to have the intake machined and buy intake gasters if RTV will work.
Old Apr 3, 2010 | 09:19 AM
Kevin Blown 95 TA's Avatar
You could try measuring what clearances you have there between the intake and heads. Use some clay if you want to and if it's a little less than .060 you might be fine with intake gaskets (I measured them at .060 last time I did this) and if its a lot more than that I might be afraid to use silicone because it might push out. If it's way less then you may just want to get it milled. If it was me, I would measure it and get the intake corrected if needed then use the right gaskets and some coppercoat. And do a dry fitment to see if your bolt holes still line up, otherwise you need to slot those a little.
Old Apr 3, 2010 | 02:16 PM
MikeGyver's Avatar
Because the block/deck have been milled, the bolt holes (and ports) will line up much better without intake gaskets. I'll find out for sure later today when I put the heads on.
Old Apr 3, 2010 | 05:39 PM
MachinistOne's Avatar
You cannot eliminate the intake gaskets and just use silicone.
Old Apr 3, 2010 | 07:51 PM
rskrause's Avatar
Moderator
It will leak w/o a gasket.
Rich
warmeck
May 1, 2015 11:30 AM
CARiD
Jan 27, 2015 06:27 AM
Elcojoe
Nov 17, 2014 10:27 PM
Snoman73
Nov 17, 2014 07:22 PM
Jul 4, 2005 05:00 PM
