intake manifold gasket and rtv
Old Jul 29, 2005 | 02:48 PM
v8pwrdz28's Avatar
ok which side of the intake gasket do i put the rtv on, on the side that touches the head, the side that touchs the intake, or both? i need to know ASAP, thanks.
Old Jul 29, 2005 | 02:58 PM
Re: intake manifold gasket and rtv
It's your choice if you want to put RTV on the gasket, itself. I didn't put any at all.
Old Jul 29, 2005 | 02:59 PM
v8pwrdz28's Avatar
ok i was going off of what haynes and chiltons say, so i will be safe with just the gasket and the rtv on the front and back?
Old Jul 29, 2005 | 03:44 PM
BUBBA's Avatar
I guess the reason the intakes leak is because GM was too stingy on the sealants at esp. the rear of the intake. so it's important to be generous with the RTV at the rear mating surfaces. With a good quality gasket a proper torqing you should be ok. JMHO
Old Jul 29, 2005 | 05:52 PM
94 NO TOP Z's Avatar
Don't use sealant on the gaskets. Lay gaskets on, retain with the white clips, put a good bead of silicone on just the front and rear of the block and around the tabs of the gaskets.
Old Jul 29, 2005 | 07:25 PM
mattbailey's Avatar
I always let the car sit at least 10 hours to let the RTV cure after fixing intake leaks.
warmeck
May 1, 2015 11:30 AM
CARiD
Jan 27, 2015 06:27 AM
Elcojoe
Nov 17, 2014 10:27 PM
Snoman73
Nov 17, 2014 07:22 PM
Jul 4, 2005 05:00 PM
