Intake manifold Gasket HELP
Old Sep 4, 2009 | 12:12 AM
lt1le2's Avatar
What is the best gasket sealer u can buy for the front and back of my instake manifold I want no oil leaks and also if u know a good procedure how to do it the best way please chime in
Old Sep 4, 2009 | 04:00 AM
69gto96z's Avatar
RTV with the fel pro kit is good, apply the bead an inch up on each side on the intake manifold gaskets, let it dry for atleast 12 hours and your good.
Old Sep 4, 2009 | 06:31 AM
KYWes's Avatar
Yup, what he said. I used the copper RTV. I was doing a major re-working of my car so the RTV had a long time to set up before use. I've got no leaks now.
Old Sep 4, 2009 | 12:26 PM
bw_hunter's Avatar
Well, this has been discussed about a million times on this, and other, forums.
The correct material to use is the GREY RTV. It's got the correct heat capabilities and, in my opinion, works better than the other options. The real secret is to apply the sealer to the cleaned block, set the manifold down on to it without moving it around, torque the bolts to spec and DO NOT START THE ENGINE FOR 24 HOURS. This allows the RTV to cure and get rid of the cure product, acetic acid. Clean the block and manifold mounting surface with acetone last...use whatever you need to remove the old silicone and gunk that's there.
I believe most guys have problems when they start the engine before the cure is complete.
You can continue to assemble the engine after you torque the manifold down...that won't interfere with anything.....
Good luck!
Old Sep 4, 2009 | 12:56 PM
lt1le2's Avatar
Gasket
Awesome thank you guys
Old Sep 4, 2009 | 01:08 PM
KYWes's Avatar
According to Permatex Grey RTV is good to 500 degrees, Copper RTV is good to 700 degrees.
Old Sep 4, 2009 | 01:11 PM
bw_hunter's Avatar
If the manifold gets to either of thise temps, the engine is toast anyway. There are other reasons to use the grey and not the copper. It doesn't matter either way to me..use what you like. You might note with interest that GM specifies Grey RTV for this application......
Old Sep 4, 2009 | 01:13 PM
Maybe because the copper is overkill. Either way, it won't hurt.
warmeck
May 1, 2015 11:30 AM
CARiD
Jan 27, 2015 06:27 AM
Elcojoe
Nov 17, 2014 10:27 PM
Snoman73
Nov 17, 2014 07:22 PM
Jul 4, 2005 05:00 PM
