Intake manifold and distribution
Old Aug 6, 2007 | 12:36 PM
Z-RATED94's Avatar
Is there anything a porter can do to help with the distribution problems of the LT1 intake manifold? Are there any other ways to work around this problem if running a large (to me anyways) shot of nitrous, say 200 RWHP. I'm looking to build a new shortblock for nitrous, but do not plan on ever running a direct port set-up. Thanks, Rick.
Old Aug 7, 2007 | 12:15 PM
Z28SORR's Avatar
Look in the Advanced Tech sect.
Old Aug 7, 2007 | 01:24 PM
Z-RATED94's Avatar
I always do, but thanks.
Old Aug 7, 2007 | 09:03 PM
I'm running a dry 300-shot on an LT4 intake that was ported by CNC Cylinder Heads, and the nitrous distribution is surprisingly uniform, proven with a huge number of engine dyno pulls.
Old Aug 7, 2007 | 09:36 PM
Z-RATED94's Avatar
Thanks Fred, but what about a wet shot? Thinks theres a diff? Just trying to play it safe and make it as easy as possable for the tuner. If it were a couple of hundred or so for better results and safer tuning, I'm all for it.
Old Aug 7, 2007 | 09:45 PM
Bersaglieri's Avatar
I've been rolling the same thought around. I think you'll find some folks just saying to direct port the stuff.
-Dustin-
Old Aug 7, 2007 | 09:50 PM
Wet can be a problem. The air turns corners, but the mass of the fuel particles make it hard for them to follow the air - they tend to keep going straight. Consider something like the NOS NOSzle system for direct port. Main problem will be raising the fuel rails.
mightymouse383
Jul 20, 2016 07:34 AM
69z-28
Jan 29, 2016 10:46 PM
HarleyZ28
Oct 5, 2015 06:23 AM
Elcojoe
Nov 17, 2014 10:27 PM
Jul 4, 2005 05:00 PM
