intake manifold !!
Old Aug 2, 2004 | 04:10 PM
ZPower_123's Avatar
intake manifold !!
So i started to take out all of the stock intake to make way for a new c.a.i & throttle body, by the time i took off the stock throttle body,
I looked inside and had seen that the whole intake manifold was just cover with crap....ahhh so i just stoped, what should i do about this?
what does a polishing cost?
Is the motor still worthy?
Old Aug 2, 2004 | 04:47 PM
CoUnTryMuZiCZ28's Avatar
Re: intake manifold !!
What your seeing is probably oil. Let me find the post.. ill get back to you.. It comes from the valve cover though, through the line that goes to the TB. I apparently happens on high mileage LT1s. When my motor was still running I used a deutsch breather filter from auto zone for like 3 bucks, stuck it in the valve cover and put the line on that.. ill get back to you gimme about 5 min..
Old Aug 2, 2004 | 04:55 PM
here I found the post.. Its a deutsch BF412 breather.. It keeps the oil out.. For the most part.. They dont last too long though, my solution was to change the Deutsch breather and the PCV valve every 2 oil changes. heres the post:http://web.camaross.com/forums/showthread.php?t=226570
To get that stuff out, while the TB is off get some carb cleaner and spray inside the intake.. dont hit the TB with it though, i heard it takes off the teflon coating on the TB, for that you use TB cleaner..
Old Aug 2, 2004 | 06:43 PM
Antz97ZNJ's Avatar
Very common problem w/ LT1's
Old Aug 2, 2004 | 11:28 PM
ZPower_123's Avatar
What is the point of having that valve cover line that goes to the TB?
Old Aug 3, 2004 | 12:31 AM
On a normal working engine it acts as a filter.. The air going through the throttle body goes TO (not from) the valve cover, when the pressure is built up it reverses. But anyhow, that line pushes air into the crank case and sweeps the crank case of gases and other harmful things and sends it up to the manifold and to the PCV system (accessed on the bottom of the manifold), the pcv system then sends those gasses through the intake system to the combustion chamber and then burns them.. If not for this system after about 3000 miles your oil would have stuff living in it and could mutate the ninja turtles.. .. And putting a breather on the valve cover only intoduces air into the pcv system and send clean un meterd air through the engine. computer can correct it but I wouldnt recommend it.. You could delete the whole PVC system, valve and all if you wanted to i guess.. I dont see why.. Alt Jar and Injuneer have convinced me to keep mine..
mightymouse383
Jul 20, 2016 07:34 AM
69z-28
Jan 29, 2016 10:46 PM
HarleyZ28
Oct 5, 2015 06:23 AM
Elcojoe
Nov 17, 2014 10:27 PM
Jul 4, 2005 05:00 PM
