Intake mani quick fix
Old May 7, 2008 | 10:54 PM
  #16
Ripley would never have found Newt in all that alien goo.
Old May 8, 2008 | 01:02 AM
  #17
SS RRR's Avatar
wow...
Originally Posted by cause4panic
But it did stop the seeping.
for now...
Old May 8, 2008 | 02:14 AM
  #18
bombebomb's Avatar
Keep in mind i did this very fast and sloppy. All i did was clean it quickly with brake cleaner and follow the instructions on the can. I did zero cleanup as you can see. But it did stop the seeping.
saves pic for egr delete image.
Old May 8, 2008 | 02:25 AM
  #19
SS RRR's Avatar
Just know it's redundant to use a blockoff plate on the egr tube port if you have a block off plate for the EGR. The port for the EGR tube (passenger side) which goes into your exhaust manifold is routed to the EGR port (dirvers side) so essentially if you block the EGR port w/ a blockoff then you are also blocking the EGR tube port. Make sense?
Ugh.. that goo just kills me.
"I've been slimed..."
DirtyDaveW
Mar 15, 2015 07:01 PM
Fatdog2
Jan 24, 2015 12:08 AM
Jazsun
Dec 29, 2014 12:14 PM
