Intake and head questions??
Old Jan 4, 2005 | 01:58 PM
calfirebird's Avatar
Im in the process of building a 383 with some LE heads. What i was wondering is i know of an intake that was ported from a 92 vette, Will this intake work on a 1995 formula? I think it will but im not sure. Also should i spend the money on the intake or not? I was thinking the afr heads should be about the same when it comes to the intake.
The heads are milled .0100 Do i need to change my push rods to a shorter rod so i dont put the springs in to a bind. Or will that just raise the lift of the cam?
Where is the cheapest place to pick up an opti and a electric water pump??
Thanks guys
Old Jan 4, 2005 | 11:18 PM
Re: Intake and head questions??
anyone?
Old Jan 4, 2005 | 11:33 PM
Flyin_Z28's Avatar
If it is an LT1 intake it should work.
What you have to be worry about when swaping cams and pushrods (especially milling heads) is the rocker/valve geometry. On Comp Cams website there is a tutorial on it. You should be ok since your not taking off that much off the heads. Just good assurance that you check the geometry after putting all the hard work/money into your motor.
If your looking for a CSI/CSR water pump, the best price I know of is $149.95 SDPC2000. Summit is $159, Jegs is $169. Don't know about the opti though. Hope this helps ya out.
Old Jan 4, 2005 | 11:37 PM
It isn't going to work. The 92 and 93 Corvette LT1's, and the 93 F-Body LT1's used batch fire injectors. They have different configuration on the fuel rails, and as a result the intakes on those cars did not have the groove on the top of the front of the intake for the diagonal fuel cross-over line. That groove is only on 1994 and newer LT1's. Your 95 fuel rails will not fit on the 92 intake manifold.
Old Jan 4, 2005 | 11:42 PM
Sweet thanks guys. Ill look at the geometry on comp cam site.
thanks cal
Old Jan 4, 2005 | 11:52 PM
Flyin_Z28's Avatar
I guess the intake won't work out for you after all.
Why don't you just get your stock intake ported? Are you worried about downtime? Getting your stock manifold ported will be near the same cost anyways. Just a thought.
Old Jan 5, 2005 | 05:59 AM
Yes im worried about downtime. I dont have a place to do this swap so i will be borrowing the space so i need to have all my ducks in a row. Does the intake need to be ported?
And picking a cam is a nightmare. IVe callled everyone and they all have diffrent opinions. Fun Fun.
Old Jan 5, 2005 | 04:23 PM
DavesLT1's Avatar
it's kinda the same here, anytime you ask a question about cams everyone has their own opinions. Just know if you want more top end or keep some extra bottom end, and if you want a lopey idle. plus a few other things to consider too, it all depends on your application.
Old Jan 5, 2005 | 06:11 PM
SAR2K's Avatar
Originally Posted by Injuneer
...the intakes on those cars did not have the groove on the top of the front of the intake for the diagonal fuel cross-over line. That groove is only on 1994 and newer LT1's...
Wow I've never noticed that... learn something new everyday, LOL.
Steve...
Old Jan 6, 2005 | 12:31 AM
SStrokerAce's Avatar
Steve...
Me too.
Old Jan 6, 2005 | 05:51 AM
Yea me to, I think i will stick to 95 and up stuff when it comes to Fuel injection.
Old Jan 7, 2005 | 01:03 AM
Originally Posted by SStrokerAce
Me too.
So how does that old saying go.... "The old dog can teach you a new trick"?
No, that's not it
Old Jan 7, 2005 | 01:52 AM
No, that's not it
Fred, I'm pretty sure that's not the only trick you have for us. ;-)
Old Jan 7, 2005 | 07:13 AM
OldSStroker's Avatar
No, that's not it
Something like that.
I like what it says on the label of Old Fart wine: "Be bold, go for the old."
Yes, that's a real wine. It's mate is Old Tart.
oldschool
Feb 9, 2016 09:21 PM
LT14LIFE
Feb 9, 2015 09:35 PM
MadMav
Feb 6, 2015 11:02 PM
95chwagon
Jan 13, 2015 09:19 PM
thenewkid
Nov 27, 2014 09:41 AM
