Intake gaskets
Old Dec 5, 2005 | 10:32 AM
walt355's Avatar
Intake gaskets
Does anyone make a intake gasket for ported intake runners? Teh last time I had to work on a set of Felpros half a day to get the intake runner holes to clear. Anysuggestions
Old Dec 5, 2005 | 10:26 PM
NastyTA's Avatar
Re: Intake gaskets
Nope. But if you tell me how you did your last set I can give you some pointers.
Old Dec 6, 2005 | 10:43 AM
walt355's Avatar
Re: Intake gaskets
Last time I took a dremil tool and a small cutoff wheel and took it real easy not to disturb the silicone bead around it.
Old Dec 6, 2005 | 04:50 PM
Z28SORR's Avatar
Re: Intake gaskets
Funny, the speed shop I buy from has a whole wall full of sbc & bbc intake & exhaust gaskets for everything from ported to raised runner and from round to square. I always got the gasket first, when port matched the intake and heads to it.
Old Dec 6, 2005 | 08:20 PM
NastyTA's Avatar
Re: Intake gaskets
Well if that's what works for you, cool deal.
You can buy gaskets that are bigger than a stock port, but you'll still need to do a little trimming since no two heads will be ported the same, except for CNC'd castings but still no gasket will match perfect.
Usually find the gasket that fits closest and stick it to the head with a couple dabs of RTV. Line it up as close as you can then let it set up. Then go back with a razor and trim the edges.Be careful not to get pieces down the ports. As for port matching, there are several different ways to layout what needs to be ground.
Gasket and port matching parts is free HP. If it's not done, the air hits a wall and you get turbulence, dead spots and HP loss. It's worth the time.
Old Dec 7, 2005 | 01:09 AM
walt355's Avatar
Re: Intake gaskets
The felpros I used last time had a metal center. Thats why I had to use an abrasive it trim it.
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
dfarr67
Apr 10, 2015 07:44 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
