Intake Gasket Questions
Old Sep 25, 2007 | 01:08 AM
chance94z's Avatar
I have a 94 LT1 and I just did a top end build on it. When I had my heads rebuilt they had to shave 30 thousandths off because of warpage. Now When I reinstalled the intake there is a gap thick enough to put a quarter in at the front and the back of the intake. How am I going to keep this from leaking oil? Thanks.
Old Sep 25, 2007 | 01:37 AM
Tekprodave's Avatar
The best way is a product called "the right stuff". It will seal it.
Old Sep 25, 2007 | 01:38 AM
chance94z's Avatar
Where could I get it at?
Old Sep 25, 2007 | 01:43 AM
chance94z's Avatar
ok, I got on Autozones website, and they have it. Thanks, I will give it a try.
Old Sep 25, 2007 | 03:55 AM
SS RRR's Avatar
In front and the back of the intake.... where?
Old Sep 25, 2007 | 04:35 PM
chance94z's Avatar
It is right at the front and the rear of the block where the intake and block meet.
Old Sep 25, 2007 | 09:58 PM
JP95ZM6's Avatar
You might need to slot some of the bolt holes in the intake, too.
Old Sep 25, 2007 | 10:39 PM
showstoppers-96-Z/28's Avatar
Even tho you shaved ur heads, the intake manifold should not have changed positions much less risen any higher, where the front (tb side) and back (egr side) of the manifold meet the block they dont sit metal to metal...this is where you are supposed to seal the manifold with RTV. unlike the 1st gen small blocks, they dont make rubber seals for the LT's, they have the manifold gaskets and then are sealed by high temp rtv silicone. if ur missing this, you will always leak oil, if you didnt seal it, pull the manifold back loose and seal it good.
Jazsun
Dec 29, 2014 12:14 PM
Noenav
Dec 6, 2014 07:35 PM
thenewkid
Nov 27, 2014 09:41 AM
