Intake bolts don't fit....
Old May 19, 2005 | 11:10 PM
94zgreenmachine's Avatar
I went to bolt the intake on and only one side fits. The other side needs to be elongated a bit. I'll take a bit off each side just to be safe. Other than that the intake seems to seal and sit tight to the heads and with the addition of the rtv, it should seal well around the rail.
How much can be milled off the heads before the intake doesn't fit properly?
Check the sig, to see info on motor. Glad I plan on ditching work tomorrow, cause I didn't get much done tonite.
Old May 19, 2005 | 11:41 PM
1racerdude's Avatar
Re: Intake bolts don't fit....
Do a little on both sides as to not mess up the port alignment,looks better too.
Should be able to go .030 with no problem on the milling.
Old May 20, 2005 | 12:05 AM
Yeah, I got to try to dig up a carbide. I got some some where. It's weird cause when you look down the hole, it looks fine but the angle throws it off abit. I tried putting bolts in there for about 10 minutes till I finally was "convinced" . It really isn't much that has to come out. Just one more obstacle to getting this together. I love working on LT1's......
Old May 20, 2005 | 12:24 AM
1racerdude's Avatar
That's the way with any of them Ford or Chevy. When ya start changing things it don't stop until it's running.
HectorM52
Jul 30, 2017 11:46 AM
Catmaigne
Dec 25, 2014 12:16 PM
thenewkid
Nov 27, 2014 09:41 AM
Jul 4, 2005 05:00 PM
