installing starter for header install
Old Mar 29, 2006 | 10:50 AM
bringBackCamaro's Avatar
Im very nervous about removing the starter for my upcoming Pacesetter
Header install on a 97 LT1 camaro
Do I need a GM fork tool to line the teeth back up correctly?
are there shims to worry about or does it just unbolt and bolt back in
with no problems?
Old Mar 29, 2006 | 10:57 AM
Re: installing starter for header install
also, can i find the install document for Pacesetter Longtubes online?
It seems like everyone is doing this install right now, can someone scan the documents and put them online
Old Mar 29, 2006 | 11:05 AM
Cman's Avatar
Mine didn't have any shims at all, if yours do make sure you put them back in the right place when you reinstall the starter. It's just 2 bolts holding it on the bell housing. Remember to disconnect the cable at the starter first after you disconnect the battery before removing the starter.
Get the two bolts loose enough that you can take them off by hand and support the starter as you remove them so no nasty surprise drops by the starter when you take that last bolt out.
When reinstalling, get the bolts started first before putting the socket to either one of them. That's about it, one of the simplier things you can re and re on these cars.
Tony
Old Mar 29, 2006 | 11:47 AM
Javier97Z28's Avatar
Moderator
Procedure:
Remove wires
Remove bolts
Remove starter
Replace starter
Replace bolts
Replace wires
Drink beer.
Old Mar 29, 2006 | 11:49 AM
redemn93's Avatar
ya i think thats how we did it.
seriously though just yank it out and throw it back in.
Old Mar 29, 2006 | 12:43 PM
wrd1972's Avatar
Originally Posted by Javier97Z28
Procedure:
Remove wires
Remove bolts
Remove starter
Replace starter
Replace bolts
Replace wires
Drink beer.
werd
There are no tricks at all to this process, two monkeys with wiffle ball bats could do this job. I did not even remove the wires except for the battery cable.
Does that help.
Old Mar 29, 2006 | 01:48 PM
The more starter installation documents i read, the more complicated it seemed to be
Can anyone post the install doc for the headers?
Old Mar 29, 2006 | 03:51 PM
2000GTP's Avatar
The install docs.from Pacesetter for the headers are not very helpful as they very vague. I did a search of previous posts and found plenty of info. that helped alot more. As for the starter, it is as simple as removing the wires and two long bolts.
Old Mar 29, 2006 | 06:06 PM
Jeff H's Avatar
Most starters are not shimmed and it only takes 2 bolts to get it out. It's a real easy reinstall so don't sweat it. The older Chevy small blocks were a PITA to get the starter shimmed and lined up right, the LT1 is great!
Jlo
Feb 23, 2015 12:20 PM
dmcdonald96
Jan 30, 2015 06:46 AM
Jason Short
Jan 19, 2015 06:34 PM
thenewkid
Nov 18, 2014 12:57 PM
