installing SFC?
Old Dec 26, 2003 | 01:25 AM
z28marine's Avatar
installing SFC?
I just got some BMR boxed subframe connectors for christmas, and was wondering for those who have installed them, how long exactly or hard was it to do?
Old Dec 26, 2003 | 01:37 AM
revtime's Avatar
Are they bolt in or weld in?
Bolt ins are not hard you should be able to install them in a few hours.
Better to have someone who can Weld to install those that need welding.
Old Dec 26, 2003 | 01:51 AM
z28marine's Avatar
they are weld in....my uncle can weld at his shop, so he can do that...and we have an air lift to get the car up, but im trying to get a rough estimate of the time needed
Old Dec 26, 2003 | 02:27 AM
revtime's Avatar
Took about 2 hours for the shop to weld in my DDs.
Old Dec 26, 2003 | 05:11 AM
QCKZ28's Avatar
i rolled into the shop with the KBDD already bolted up, it took the guy a little over an hour to weld them up real good, i had mine done at the local exhaust shop for $15
i just showed him where to weld and he welded
jesse
Old Dec 26, 2003 | 10:18 AM
Red96Lt1's Avatar
Do note that they are talking about DD's. I would assume that your boxed wouldn't taked near as long.
Old Dec 26, 2003 | 01:32 PM
PoorMan's Avatar
I don't know if it REALLY matters but I have heard that it is best to half them welded with the suspension fully loaded. So a drive on lift is prefered.
Jeff D.
Old Dec 26, 2003 | 01:36 PM
Red96Lt1's Avatar
Jeff D.
Yes, you deffantly want the suspension loaded!
Old Dec 26, 2003 | 08:00 PM
S.J.S.'s Avatar
Yep drive on, and those BMR's shouldn't take them more than 20 minutes for both.
Old Dec 26, 2003 | 08:14 PM
stereomandan's Avatar
It definately takes more than 20 minutes. I would say about an hour on average. My BMR tubular's took even longer than that, but we did the welding ourselves and were taking our time. You have to unbolt the rear control arm and bolt the SFC to that hole. Than you need to prep the surfaces for welding(grinding down to bare metal.) Then line them up. Then weld them. And yes, you want them on a level surface with the suspension loaded. Also, you will want to paint the area after it has been welded to keep rust from building up.
Dan
Nov 18, 2023 07:21 PM
HarleyZ28
Oct 5, 2015 06:23 AM
1996LT1Z28
Apr 14, 2015 07:15 PM
87Aerocoupe
Jan 10, 2015 07:27 PM
GA93FORMULA
Jul 24, 2002 11:38 PM
