Installing OPTI...
Old Oct 23, 2003 | 02:26 AM
S.J.S.'s Avatar
Installing OPTI...
Im reading my manual and it says "Insert the distributor nit onto the splined shaft exactly the same relation to the block in which it was removed. Are they talking about just putting it on the right way...right side up.... or is there spline matching or something. The reasone I ask is that I'm gonna be assembling my motor and wasn't sure if it had to line up in any way.
Old Oct 23, 2003 | 03:40 AM
InjectedSS's Avatar
Re: Installing OPTI...
that doesn't apply to you.. that's only for the 93 & 94's.. All you have to do is line up the cam dowel with the hole in the opti and your good to go
Old Oct 23, 2003 | 07:42 AM
Hyperspeed97z28's Avatar
heres a good site for a little help....
http://www.streetillusionsracing.com.../opti/opti.htm
Old Oct 23, 2003 | 08:05 AM
Just make sure you use the right slot on the opti.
Old Oct 23, 2003 | 09:19 AM
LT1TONY's Avatar
There is 3 slots on the back of the opti and it looks like a clover.
The 2 slots has a smaller tighter gap in the middle, thus not allowing the dowel pin from the cam to go in these 2. The slot that has the bigger opening is the one you need. It will go on nice and easy. If you are forcing it, your probably trying to put it in one of the other slots which is incorrect.
Nov 18, 2023 07:21 PM
Victor Lamb
Aug 26, 2017 02:52 PM
Richardan15
May 30, 2015 08:36 AM
1996LT1Z28
Apr 14, 2015 07:15 PM
Carogna'sZ-28
Feb 3, 2015 07:04 PM
