Installing motor from the top
Old Dec 21, 2004 | 01:20 PM
AlmostfastLT1's Avatar
I am installing my new motor from the top in my 94z. I know it is easier from the bottom etc etc. Where is the best place to put the bolts so I can move it around on the chain. I can get it straight down but, I still have to go back about 6inches to get on the motor mounts. Thanks for the help.
Mark Tisdale
Old Dec 21, 2004 | 01:30 PM
stew's94z's Avatar
Re: Installing motor from the top
I used the TPIS Happy Hooker.
It locates at the center of the weight balance point on the top of the intake and uses one chain.
It works real nice and I recommend it.
Dean
Old Dec 21, 2004 | 01:32 PM
Where did you get one etc.
Also, anyone else???? on installing motor from top.
thanks
Old Dec 21, 2004 | 01:46 PM
stew's94z's Avatar
I called TPIS over the phone and ordered one.
952-448-6021
Dean
Old Dec 21, 2004 | 04:10 PM
94zrag's Avatar
I attatched a chain to the front and rear manifold bolt holes, and then just kinda put some weight into it to move everything where I needed it to go.
Old Dec 21, 2004 | 04:46 PM
yea I did that and I had a problem lining up the motor mounts
cmking26's Avatar
I used a leveling bar. It had 4 chains and bolts. I hooked two chains to the front intake holes and the rear two chains to the third or fourth intake bolt holes. That way it didn't hit firewall when putting it in. Just have to manuever trans a little by hand.
Old Dec 22, 2004 | 11:53 AM
man I got the drivers side motor mount, and the passenger motor mount is like 3 inches off
I have a new bmr k member???
Collector Car
Jan 5, 2015 10:58 AM
Jazsun
Dec 29, 2014 12:14 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
