Installing motor with headers already in place
Old May 2, 2005 | 06:14 PM
rsjay's Avatar
I am installing my 1994 LT1 back in my Camaro. I was wondering if I could put my headers in place with my Y pipe and just install my motor. Just thinking to make things a little easier. Will they be in the way for the motor mounts and when I install the tranny. Headers are Mac mid-lengths.
Old May 2, 2005 | 06:20 PM
Daryn95Z's Avatar
Re: Installing motor with headers already in place
You can install the motor with shorties attached, I'm not sure about mid-lengths.
If you have your motor and trans. pulled out of the car, it makes things alot easier if you put the two together outside the car. The trans. attached will put just enough weight towards the back to tilt the motor at the perfect angle to just slide in.
Old May 2, 2005 | 07:07 PM
96ta(nick)'s Avatar
If you do it from the bottom you can install it with the tranny and long tubes attatched no problem
Old May 2, 2005 | 08:35 PM
Mystic97Z's Avatar
thats the way i do mine..
Old May 2, 2005 | 11:50 PM
rsjay's Avatar
I do have both the tranny and engine out of the car. I was wondering if I could put both back in the same time. I thought I never had enough room?
Old May 3, 2005 | 12:47 AM
RicocheT's Avatar
Yea theres enough room, the only problem I had was the steering shaft.
LeftoverChinese
Jan 14, 2024 03:03 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Collector Car
Jan 5, 2015 10:58 AM
hotrodyou1
Dec 20, 2014 10:05 PM
