Installing mechanical oil temp gauge w/o dropping pan
Old Apr 28, 2006 | 09:32 PM
Brad Haskett's Avatar
Post Installing mechanical oil temp gauge w/o dropping pan
If anyone else is interested in installing a mechanical oil temperature gauge on your LT1 F-body without dropping the oil pan, you can use the hole for the factory oil level sensor in the driver's side of the pan. The proper M20x1.5 to 1/2" NPT thread adapter that you need is part# 7537K2 from McMaster-Carr (mcmaster.com). The Auto Meter fitting threads right into that adapter. The additional length of the adapter put the oil temp tube pretty close to my FLP full-length headers, so I had to insulate the line where it passes the primaries. Of course, you'll have to check your oil level the old-fashioned way, but hopefully you're already doing that anyway.
HTH,
-Brad
Old Apr 29, 2006 | 10:03 AM
Loadre's Avatar
Re: Installing mechanical oil temp gauge w/o dropping pan
haha Nice first post you lurker.
Old Apr 29, 2006 | 11:29 AM
lethal93ta's Avatar
why would you want to get rid of your low oil sensor? there is a fitting right above the oil filter where you can put it.
Old Apr 29, 2006 | 02:49 PM
Lethal-
The port above the oil filter is good for pressure, but you can't put a mechanical temperature gauge there. The hole is too small for the bulb.
-Brad
Old Apr 29, 2006 | 11:51 PM
lethal93ta's Avatar
just spend the money on a electracial one it has a 1/8 sender and fits right in there.
Old Apr 30, 2006 | 12:01 AM
Hawk's Avatar
Yep, thats what I did, works great.
The port above the oil filter is the BEST spots hands down for oil temp sender.
Brian
Old Apr 30, 2006 | 10:48 AM
GetaZforgetGT's Avatar
Good find...this will work for those of us who are running strokers and can't use the oil level sensor anyhow.
At the bare minimum this give me a plug that fits the hole. I haven't located anything else yet.
94Z28LS1toLT1
Jul 10, 2024 05:17 PM
cmdeshon
Dec 27, 2014 10:06 AM
brentbrowning01
Dec 16, 2014 06:35 AM
ro2207
Dec 4, 2014 06:18 PM
GigaMp3z
Feb 20, 2003 02:57 PM
