Installing the LT1. VATS disabled???
Old Mar 3, 2006 | 01:37 AM
Rage's Avatar
First off, Im at a very confusing stage in life where I am confused as to which section to post in, the third gen section or the LT1 section. All that aside, I have a 1994 LT1/T56 going in my 87 Camaro. Must I disable the VATS in order for my car to start? If so, how is this accomplished? If I can do it without spending money, I would like to, please help, Im running out of time on this. Thank you.
Old Mar 3, 2006 | 07:26 AM
Dave89IROC's Avatar
Re: Installing the LT1. VATS disabled???
first, yes, you need to disable VATS
two ways to do it, get the PCM flashed to turn it off, or, get one of these
http://cgi.ebay.com/ebaymotors/GM-VA...42451910QQrdZ1
Old Mar 3, 2006 | 07:31 AM
Most VATS questions end up in the General Tech section (all years in that forum). You will have to spend a little money. It will cost less than a dollar to buy a resistor to bypass the key pellet, but that is not the only thing you have to do. You must also either re-program the computer to eliminate VATS or buy a bypass module that mimics the fuel enable signal the VATS module sends to the computer.
Another option instead of using a resistor to bypass the key pellete is to bypass the theft deterrent relay by wiring around it. That enables you to engage the starter, but you still must have the bypass module or VATS programmed out for the car to run.
Old Mar 3, 2006 | 02:45 PM
Dave89IROC's Avatar
shoebox, the resistor trick won't work for him, he put a94 LT1 in a 87, which had no VATS, so he needs either it turned off in the PCM, or the box I linked that sends the correct signal to the PCM(the signal originally sent by the VATS module/BCM)
Old Mar 3, 2006 | 05:43 PM
I did not know how far back VATS went and sometimes I get caught up with 4th gen thinking.
Old Mar 3, 2006 | 06:33 PM
Dave89IROC's Avatar
thats what I figured, just FYI, VATS was a rare option on 88 f-bodys, pretty much standard in 89
Old Mar 3, 2006 | 07:56 PM
Hotwire's Avatar
Send me $10 and I'll send you the vats bypass module I made, I bought a cable and tuned it out of my pcm.
Nov 18, 2023 07:21 PM
Lakebratt
Feb 5, 2015 07:55 PM
cmdeshon
Dec 27, 2014 10:06 AM
Fedesna
Nov 23, 2014 11:06 AM
