Installing LT1 aluminum heads procedure
Old Apr 14, 2014 | 11:26 AM
4586's Avatar
Compared to standard iron heads is there any unique procedure required to install LT1 aluminum heads on an iron block? I see a lot of head gasket kits include new headbolts...is that an absolute or is it common to reuse the bolts with thread sealer?
Old Apr 14, 2014 | 11:46 AM
Chimera96's Avatar
Re: Installing LT1 aluminum heads procedure
I have re-used the stock head bolts before. no difference in installing iron vs al heads
Old Apr 14, 2014 | 12:15 PM
It depends on the year of the car as far as the head bolts go. 96 and up (and some late 95s) are TTY and cannot be reused. If you want to take the safe route, buy some ARP bolts and don't worry about it.
Old Apr 14, 2014 | 12:19 PM
4586's Avatar
It's a 95 engine..how do I tell the difference?
Old Apr 14, 2014 | 12:36 PM
Chimera96's Avatar
does the timing cover have a crank sensor lower passenger side?
96 did, 95 and earlier did not
regarding re-using head bolts, while I have without issue (on a 96) I would and do now just use ARP.
Old Apr 14, 2014 | 01:53 PM
Non TTY bolts look like the old SBC head bolts. The TTY ones tend to be a little more slender and silver looking.
While all bolts stretch, TTY bolts are made to stretch to a certain degree to create a uniform clamping force. That is why the tightening sequence is different. Once they stretch, they don't return to the original length (as much as a non TTY bolt would). Reusing them could result in breakage or loss of proper clamping strength. As suggested, I would buy some ARP bolts. Cheap price to pay for something as important as the head seal on an LT1.
Old Apr 14, 2014 | 02:20 PM
He's asking about the difference between an "early" and "late" 95. No 95's have a CKP sensor.
Old Apr 14, 2014 | 05:06 PM
4586's Avatar
Thanks for the responses....looks like I have the standard bolts...and can pick up a new set for under $25 just in case.
Old Apr 15, 2014 | 08:09 AM
Change the bolts, unless you have a detailed knowledge of their history. Here's a good article on head bolt tightening technology.
http://www.sbintl.com/tech_library/a...e_to_angle.pdf
The important part is at the end:
A final subject is the relative merits to re-using critical fasteners. If I had a dollar for every head bolt I’ve wire brushed and reused I could afford a pretty nice vacation next year. There are very few of us in this industry that haven’t reused critical fasteners!
However, times change, engines change, technology changes, I’ve changed. My policy is that if new critical fasteners – especially head bolts – are readily available, old ones are replaced. Understanding much more about fasteners and engine operating conditions today, I’m reluctant to reuse them.
A well-respected OE engineer specializing in engines tells me that critical fasteners have about six rundowns in their useful life. They use four of those at the OE manufacturing operations, leaving rebuilders just two. One rundown for checking sizes puts us on the last rundown during final assembly. My thinking is: why take the chance? Replace the fasteners! The relative cost compared to the total engine job is small and the peace of mind is great.
Reprinted by permission of Engine Builder magazine
If the bolts are conventional, they were installed to a torque spec. If the factory did it, the thread prep, lubricant and the tightening process were carefully controlled. If at some point in it's life the head were removed and reinstalled, the process falls apart. 90% of the torque value is due to friction. The rest has to do with bolt stretch. The process is subject to limitations on block thread prep (were the threads properly chased?), the lubricant uses, cleanliness, accuracy of the torque wrench, skills of the installer, etc. The bolt could be installed to the proper degree of stretch, or it could be over-tightened or under-tightened. If marginally over-tightened, what happens when the aluminum heads get a bit too hot, and the aluminum expands more than the steel bolt, due to the significant difference in the coefficient of thermal expansion of steel vs. aluminum? The bolt could have been stretched beyond it's elastic limit.
Noenav
Mar 1, 2019 07:38 AM
*Emilia*
May 13, 2015 09:05 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Brandon Wittmer
Dec 7, 2014 12:15 PM
