Installing Hub?
Old Mar 12, 2004 | 02:14 PM
JJ's95B4C's Avatar
Installing Hub?
Ok...i'll be doing this tomorrow morning. I rented the hub install tool from Autozone, but I realized after that it will not work. Now what? Can I just put a block of wood on front of it and hammer it on? I've read on other threads that if i use the stock bolt i may strip the threads inside the crank, and i really don't want to do that! So what are my options at this point? I dont think i'll find a threaded rod to do the install by tomorrow morning.
Thanks.
Old Mar 12, 2004 | 11:18 PM
JJ's95B4C's Avatar
Sorry to TTT this, but i'm doing this as soon as the sun comes up! Please help.
Old Mar 12, 2004 | 11:30 PM
Though I have seen it done, I don't recommend pounding the hub on. Threaded rod or proper install tool is the way.
Old Mar 13, 2004 | 12:27 AM
JJ's95B4C's Avatar
I forgot to mention, i rented a hub install tool today from autozone, but i don't think that it will work. Its a long bolt, and a threaded part goes over the bolt, and the nut goes on that threaded part. The problem is that the threaded part is huge. I think i'll go to napa and get that leaf spring bolt if the install tool i rented doesn't work.
Old Mar 13, 2004 | 12:55 AM
97WS6SCharged's Avatar
I've always heard that pounding the hub on can damage the crank bearings.
Nov 18, 2023 07:21 PM
HectorM52
Jul 30, 2017 11:46 AM
cyteone
Feb 7, 2015 06:04 PM
Chevyguy358
Jan 28, 2015 08:04 PM
