Installing headers on a 97 camaro
Old Jun 7, 2012 | 09:36 PM
my1994z28's Avatar
I am hoping this is the correct section for this question...This is my first completely "stock" lt1 camaro,I am installing ceramic coated pacesetter long tube headers,I am removing the cats,and emission componets...My question is where do I relocate the O2 sensors to?I have not received the headers yet,so i dont know if they have provisions for the 4 O2 sensors.I know that they have 2 locations for them,but i am unsure about the other 2.Any help or suggestions is appreciated.
Old Jun 7, 2012 | 09:48 PM
lt11997's Avatar
Re: Installing headers on a 97 camaro
You don't use the rear ones, you'll have to get 02 simulaters or tune them out of the pcm. The front 02s go in the headers and you'll need to buy wire extension harness for both of them. Some people cut the factory harness and splice in extra wire but I don't recommend cutting up the factory harness if it isn't necessary.
Old Jun 7, 2012 | 10:45 PM
my1994z28's Avatar
Ok,thanks...Are the square plug or flat plug considered the rear o2s?Also what company can i get the simulators from?
Old Jun 8, 2012 | 05:17 AM
RamAir95TA's Avatar
Rear O2s use 4-pin square connectors.
Just about any site sponsor can get simms for you.
Old Jun 8, 2012 | 10:49 AM
6SpdLT1Z's Avatar
I put Pacesetter LTs on my '97 SS a couple years ago.
You said you aren't running cats, why would you keep the rear o2 sensors? Tune them out or buy o2 sims. As Joe said, the rear o2's use square 4-pin connectors. Fronts use flat 4-pin connectors.
As far as purchasing o2 simms, look at our site sponsors. Here's a link for what you're looking for. You'll need 2. Speed Inc - Pure Power
Personally, I'd use that money and spend a little more on a mail order tune and have the rear o2's tuned out.
Here's a couple threads on my setup:
https://www.camaroz28.com/forums/lt1...s-list-735320/
https://www.camaroz28.com/forums/lt1...1470-a-731659/
https://www.camaroz28.com/forums/lt1...nsions-731199/
Old Jun 8, 2012 | 05:17 PM
my1994z28's Avatar
ok thanks guys,I am going to have them tuned out..
Old Jun 9, 2012 | 08:14 PM
CamaroBoy96Z28's Avatar
Do that. I had mine tuned out. Header swap is not too bad. I did it on my 96 and a buddy's 94. Undo the motor mounts and jack up the motor as needed. I think I did both from the bottom...its been 9 years so I don't remember exactly what I did.
Old Jun 10, 2012 | 10:02 PM
my1994z28's Avatar
I have both manifolds,emission parts,y-pipe,etc removed..Just waiting on UPS to bring the headers and y-pipe tomorrow...
Old Jun 28, 2012 | 11:54 AM
mrcallison's Avatar
Did you use 02 sims or tuning? I currently dont have my 02 sensors hooked up
Old Jun 28, 2012 | 01:24 PM
RamAir95TA's Avatar
O2 simms are for deleting the rear O2s. The front O2s are required for fuel trim from the PCM so they need to be functional.
Old Jun 28, 2012 | 03:16 PM
my1994z28's Avatar
Ended up getting the rears deleted out...
hotrodyou1
Dec 20, 2014 10:05 PM
Dec 4, 2014 11:56 AM
Jul 4, 2005 05:00 PM
GigaMp3z
Feb 20, 2003 02:57 PM
