Installing guideplates
Old Nov 11, 2007 | 02:34 PM
95z28man's Avatar
Do you put the guideplates over the studs, or put the guideplates on, then studs on top?
Old Nov 11, 2007 | 02:48 PM
WS6T3RROR's Avatar
The second one.
Old Nov 11, 2007 | 07:31 PM
1racerdude's Avatar
Old Nov 12, 2007 | 12:00 AM
whitehooptie's Avatar
Yes, take ALL of the studs out of the head, put the guide plates in one cylinder at a time and bolt them down to proper specs. Too loose can make them fall out. Too tight can cause breakage wether 2000 miles later or as you are bolting them on.
Do you know how to set your rockers?
Old Nov 12, 2007 | 07:13 AM
95z28man's Avatar
If your talking about just putting the rockers on correctly, then yes. If your talking about adjusting them, I've never done it before, but I have the basic idea down.
Old Nov 12, 2007 | 08:27 AM
METALBEAST's Avatar
Guideplates first. THen put the studs on.
Old Nov 12, 2007 | 07:31 PM
OBE1 95Z28's Avatar
Study up on how to properly set your valve lash. A lot of people do it incorrectly; some end up bending push rods
Old Nov 12, 2007 | 10:43 PM
When the intake valve is about to close, adjust the exhaust valve.
when the exhaust valve is about to open adjust the intake valve
Old Nov 13, 2007 | 10:07 AM
2QUIK6's Avatar
Be sure to get new studs that are for use with guide plates, the threads are a little longer as the stockers will not have enough thread once the thickness of the plate is introduced.
And I take it you have new rockers that are non-self aligning right?
And hardened pushrods that are for use with guideplates and correct length?
Nov 18, 2023 07:21 PM
Victor Lamb
Aug 26, 2017 02:52 PM
1996LT1Z28
Apr 14, 2015 07:15 PM
Carogna'sZ-28
Feb 3, 2015 07:04 PM
Catmaigne
Dec 25, 2014 12:16 PM
