Installing a GM847 soon
Old Feb 7, 2006 | 11:23 AM
Matts1994Z28's Avatar
Im about to buy a GM847 for my lame 355. i have about 1000-1200 i want to spend on my cam swap, i want to be sure i get all good parts. what all should i get? i know im need a new timing chain set, im gonna get a new oil pump, i already have roller rockers but im not sure if they are 1.6's or what. i know i need new springs, pushrods and maybe lifters also. what else am i missing guys? if possible could someone make me a list and let me know where i should oreder this stuff it would be greatly appreciated!! thanks in advance!
Old Feb 7, 2006 | 11:29 AM
Re: Installing a GM847 soon
also would i be able to keep my roller rockers that i have or should i ditch em and get new ones?
Old Feb 7, 2006 | 11:35 AM
91RSLT1's Avatar
Do you know what kind of rockers, brand wise? Look at the rocker body they might have the ratio stamped on them. I would think they should be fine but hard to say will such little info.
Old Feb 7, 2006 | 11:40 AM
Yeah i havent pulled the covers to look at them, they were installed when the motor was built right before i got the car. the work order didnt specify, it just says roller rockers. i guess i could pull one of the covers this afternoon and find out.
Old Feb 7, 2006 | 11:49 AM
This exactly what has been done to my car..minus the mild head work.
8 1030 hyper pistons
1 set 1030 moly rings
overhaul gasket kit
3 piece timing set
8 std rod bearings
1 set std main bearings
1 oil pump
1 oil pump pick up
1 oil pump drive
1 police roller cam
1 set roller tip rockers
bore .030 over
polish crank
press work (pistons)
block prep
valve job #3
for a grand total of $2,066.95
now all of this was done back in febuary of 2001 at 74,000 miles, just last week i rolled over 100,000!!! it was a sad day...
Old Feb 7, 2006 | 09:27 PM
ttt
Old Feb 7, 2006 | 11:20 PM
Z95m6's Avatar
I'd not get an oil pump as i see no reason to. I'd also make sure you get a good timing chain as i'd assume from the price of your rebuild you're running a stock chain. You need to get more info on the roller rockers.
Old Feb 8, 2006 | 10:27 AM
Yeah they place who built the motor doesnt know...i still need to pull the valve covers and see if they are stamped or what not.
Nov 18, 2023 07:21 PM
Victor Lamb
Aug 26, 2017 02:52 PM
1996LT1Z28
Apr 14, 2015 07:15 PM
LT14LIFE
Feb 9, 2015 09:35 PM
Carogna'sZ-28
Feb 3, 2015 07:04 PM
