installing front seals
Old Sep 17, 2005 | 01:33 PM
Deez95ZM6's Avatar
Trying to get the seals put into my timing chain cover. I got the small one for the water pump shaft in using a socket to hammer it in. How do I get the other ones in?! Is there a tool you can rent from AutoZone that helps with this or something? Any suggestions would be greatly appreciated...
Old Sep 17, 2005 | 06:07 PM
1racerdude's Avatar
Re: installing front seals
Ya can use a hammer to start them square and a large dia. metal rod to drive them,but hit them on the 90* edge only and just hard enough to move it hitting from one side to the other and get it square. A seal driver would be nice but it's a lot of buck's.
Tip:If '93-'94 put the opti drive in the seal and fix it where seal is not turned wrongside out,same with pump drive except just check the pump drive to get seal right. Leave them in the seal and carefully install cover and place drive shafts in their place while installing before bolting.
Brake_L8
Jan 20, 2015 09:44 AM
Jazsun
Dec 29, 2014 12:14 PM
Dec 4, 2014 11:56 AM
The Seer
Nov 20, 2014 06:32 AM
