installing a electric fp guage
Old May 25, 2005 | 06:17 PM
red 95 z28 lt1's Avatar
im in the process of installing a electric fp guage and i have everything apart i know where the red and black wires to go for power and the wires to the sender but the white wire is my problem. it says it goes to a switchable 12v or the switch to turn on the instrument cluster lights but im not sure which wire on the back of the switch in the harness im pretty sure its the one that is brown and is small but im not to sure cant check with a tester b/c engine and battery is out of car. any help is greatly appreciated thanks.
Old May 25, 2005 | 08:53 PM
disco192's Avatar
Re: installing a electric fp guage
Ok....
When wiring gauges, you need Power, Ground, Signal, Ignition and/or dimmer. The power and ground are obvious. The ignition you can tap from the fuse box. The dimmer you can tap from the radio if you know what you are doing.
The simplest way is to wire the ignition wire, so the gauge light is always on when the car is on. It is tougher to wire in the dimmer, but it is nice.
Re-read the instructions. Im not sure which wire is the dimmer wire off hand. The dimmer sends a variable voltage signal up to 12v.
Old May 26, 2005 | 05:24 AM
slopokrodrigez's Avatar
To get to switched, dimmed or otherwise, you don't need to go to the switches. Get it right from the fuse panel. What's nice about that is it's easy to get to and you can get taps that slide over the blade of the fuse and allow a slip on connector to be pushed on.
If it says to put it on the IP lights, jump off the I/P Dimmer fuse number 13. This will give you lights when the IP lights are turned on and it will dim with them also.
Nov 18, 2023 07:21 PM
robcarnut
Mar 20, 2015 03:40 PM
Jul 4, 2005 05:00 PM
GigaMp3z
Feb 20, 2003 02:57 PM
