installing double rollerer tc - not enough slack?
Old May 27, 2005 | 10:40 AM
96_pimped_out's Avatar
I drove the crank sprocket on all the way and then lined the chain and cam sprocket up (marks pointed at each other 6 and 12 oclock) but i can't get the cam sprocket over the cam dowell (3 oclock) to save my life because I can't get enough slack. Is there some trick? I've been at it over an hour...
PS - cloyes pn 9-3145, the same one others run.
Old May 27, 2005 | 10:59 AM
Compstall's Avatar
Re: installing double rollerer tc - not enough slack?
Heat that sucker up in a pan. It'll slide on like butter.
Old May 27, 2005 | 11:03 AM
Heat what up? The chain? As in in a pot of water on the stove?
Old May 27, 2005 | 11:28 AM
Z28SORR's Avatar
Put it in the stove at 150* for 30 min. Check for glazing and color.......no wait.....wrong forum.
I believe he means to heat the chain in the oven for a few minutes. Not more than 200*.
Old May 27, 2005 | 12:24 PM
No need to heat anything. Just spin the cam until the dowel pin is in a lower position, slide the cam gear on it, then spin the cam back to the correct position and then put the cam bolts in.
Old May 27, 2005 | 12:28 PM
Pasky's Avatar
I just take the hub sprocket and cam sprocket and put them on at the same time. Simple that way....
Old May 27, 2005 | 12:30 PM
Compstall's Avatar
Eh, nevermind I thought you were talking about the crank sprocket..
Old May 27, 2005 | 03:58 PM
96ta(nick)'s Avatar
Goes on fine like that.
Old May 28, 2005 | 02:53 PM
I ended up getting using shoebox's method, I'm not sure why I didn't think of that, it's definately the easiest if not the only way!
Thanks guys... I've got the whole front end assembled and it's down to heads/intake now!
DirtyDaveW
Mar 15, 2015 07:01 PM
nikolt1
Feb 27, 2015 09:10 PM
Queens94z28
Dec 20, 2014 09:11 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
97 RedSS
Jun 10, 2003 07:58 PM
