Installing double roller timing set
Old Apr 7, 2005 | 11:46 PM
tjwong's Avatar
When replacing the LTx timing set with a Cloyes or similar double roller timing set. Which part number is prefered. I tried a Cloyes 9-3145 True roller set and the cam gear hits the cam retainer plate screws. Any suggestions? This set is supose to fit all 86 and up blocks originally equipped with a roller cam.
Old Apr 7, 2005 | 11:55 PM
simple's Avatar
Re: Installing double roller timing set
thats it
sounds like you dont have it lined up right
i had a little bit of trouble with mine when 1st trying too install it
after playing around with it for a while, it finally went on without further issue
can you get all three bolts thru it?
youi know about clearancing the timing cover with that setup right?
EDIT: i re read your post
you sure you have the cam gear on correctly? not on backwards...
Old Apr 8, 2005 | 09:30 AM
tjwong's Avatar
Originally Posted by simple
thats it
I gotta look because its the machine shop that said it wouldn't fit. He came by my shop today to look at the stock gear. Not sure whats going on. I am 99.9% sure that the block is the same in respects to cam retention and demensions as any small block with a roller cam since 86. And that is what this cloyes gear set is for.
Thanks!
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
Queens94z28
Dec 20, 2014 09:11 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
97 RedSS
Jun 10, 2003 07:58 PM
