Installing cat-back questions
Old May 15, 2005 | 06:27 PM
Paul87's Avatar
I got a TSP rumbler catback and the SLP installation kit also. Where do I have to cut the stock exhaust off at? I have access to a lift and a sawzall, but I've never done anything like this before. Any other tips I need to remember before I do this?
Thanks a lot guys
Old May 15, 2005 | 06:31 PM
BLinindoll's Avatar
Re: Installing cat-back questions
I thought they all just bolted right up to a flange. Maybe i'm wrong.
Old May 15, 2005 | 07:03 PM
Paul87's Avatar
It's that easy? I thought the old exhaust would be so rusted that i would have to cut it
Old May 15, 2005 | 07:07 PM
BLinindoll's Avatar
if its that rusty then just get some PB Blaster and spray it on and let it soak for a few minutes. If it's still bad, spray it again and try to work the nuts off. They should come off. After you get the flange undone, you might have to cut it near the axle so you can get the old exhaust out.
Old May 15, 2005 | 07:12 PM
FastZinTennessee's Avatar
Unbolt the flange, then you will have to cut the existing exhaust somewhere just in front of the axle. Remove the straight piece of pipe that goes between the flange and the cut, then work the back section out.
Old May 15, 2005 | 07:16 PM
Paul87's Avatar
OK so thats why I was told I needed to cut the old exhaust. Had me confused.
You guys rule, thanks for the help
Old May 15, 2005 | 07:18 PM
Paul87's Avatar
Oh yeah, I can reuse my old tips on this right? I ordered it without the tips
Old May 15, 2005 | 07:27 PM
BLinindoll's Avatar
Good luck getting them off, unless they're aftermarket tips. Stock ones might take a little work and some cutting and welding.
Old May 15, 2005 | 07:32 PM
Paul87's Avatar
Well I'm putting it on at the auto shop in school, the welding shop is right next to it
Old May 15, 2005 | 07:35 PM
BLinindoll's Avatar
Well there you go. Good luck and have fun.
Old May 15, 2005 | 07:36 PM
Paul87's Avatar
I sure thank you guys
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
nautilus
Aug 22, 2002 11:49 PM
Chrisdude
Jul 24, 2002 02:25 PM
squirrels
Jul 13, 2002 01:58 AM
