Installing a 52mm Throttle Body
Re: Installing a 52mm Throttle Body
Its fairly easy. Just unhook all connectors, coolant hoses, vacuum lines, and throttle linkage, then unhook the four bolts in the front of throttle body to pull it off. Its easy just look at it from every angle and you can see what needs to be unhooked. I did mine the first time without a clue on how to do it and I was fine.
Very easy and straightforward. Takes no more than 25-30min to swap TBs. I had everything (intake elbow, cai, radiator, condensor,etc) off too so it went even faster.
Originally Posted by 944v8inDFW
100% bolt on. Only thing i wouls say is to make sure to replace the base gasket between the TB and the intake.
oldschool
02-09-2016 09:21 PM
07-04-2005 05:00 PM
