Installed relocation brackets, now e-brake is stuck on! help! asap!
Old Oct 18, 2004 | 06:44 PM
madhatter's Avatar
BMR weld on. Now the brake is stuck on. any ideas? I need help ASAP!
Old Oct 18, 2004 | 09:39 PM
BlownF1's Avatar
Re: Installed relocation brackets, now e-brake is stuck on! help! asap!
Go under and mess with the ebrake cable attachement towards the rear just above the driveshaft...there's 2 cables and a bracket there. Mine got tweaked and stressed at one point during the fuel pump install and it bound up. Just wiggled it and it popped back in place...hopefully yours is the same.
Old Oct 18, 2004 | 11:33 PM
IrocSS85's Avatar
the lever may be rusty and sticking applied. can you pull the ebrake lever back at the caliper, where the cable goes on to it? if thats it, just spray some pb blaster on there and work it out. worth a shot. another idea may be the cable is rusted inside the cable housing.
Old Oct 19, 2004 | 12:34 AM
Z95m6's Avatar
I believe when you install the brackets you are suppose to grind on the E-brake weight to gain clearance. Did you do this? I don't know if thats the problem but it might be.
Old Oct 19, 2004 | 08:45 AM
BlownF1's Avatar
That's a great point...my installer removed those and gave them to me as "extra" parts. What function do they perform? Keep the cable tight when not in use?
Old Oct 20, 2004 | 01:32 AM
madhatter's Avatar
If someone could post somepics for me, that would be great.
HectorM52
Jun 23, 2016 08:42 PM
87Aerocoupe
Jan 10, 2015 07:27 PM
thenewkid
Nov 27, 2014 09:41 AM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
