Installed opti and new waterpump help
Old Oct 2, 2004 | 05:24 PM
brad20653's Avatar
I installed a new opti and waterpump today and started fine but goes past the hottest point fairly quick, no fluid leaks at all. When i filled the radiator i just filled it and didnt bleed it could that be it??? I also put blue rtv on the temature sending unit could that of broke it?? How do i bleed the radiator where are the bleeders?? Also maybe i have the hoses on wrong, anyone have a pick of what hoses go where??? Thanks
Old Oct 2, 2004 | 05:43 PM
Re: Installed opti and new waterpump help
The last parts of this procedure is how you should have filled it back up. There are hose diagrams on my site as well.
Old Oct 2, 2004 | 05:53 PM
Z95m6's Avatar
you need to bleed the system. When i first swapped my waterpump yrs ago i didn't fill up the pump with coolant. I just filled up the radiator with coolant and it took forever to bleed all the air out of the system.
Old Oct 2, 2004 | 05:58 PM
brad20653's Avatar
Ok thanks guys so is that a yes it can cause overheating?? Never overheated tell I did this.
Old Oct 2, 2004 | 06:23 PM
Spinner's Avatar
The water pump sensor isnt for your dash gauge, so your seeing heat/air. Bleed the system per shoebox's instructions and you'll be fine.
Sergio
Jan 27, 2016 04:27 PM
nikolt1
Feb 27, 2015 09:10 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
pologreen97z
Dec 2, 2014 10:42 AM
