installed new starter??
Old Sep 7, 2004 | 11:32 PM
flusz28's Avatar
the new starter i installed on my 94 z28 , just spins i can't get it to inguage? what could be causing this??
Old Sep 7, 2004 | 11:54 PM
Re: installed new starter??
Did you hook up the two wires correctly? Spins, but does not engage the gear?
Old Sep 8, 2004 | 08:12 AM
flusz28's Avatar
well the one bolt where the postive cable the big one goes can only go one place. the small one i just put it on the bolt where the nut was set when i took it out of the box.. so you think its on there worng then- yes it just spins
thanks
Old Sep 8, 2004 | 08:25 AM
If it only comes on when you turn the key, I would say something is wrong with the solenoid or bendix and you should take it back. The smaller purple wire should go to a terminal marked "S" (if so marked).
Old Sep 8, 2004 | 08:34 AM
flusz28's Avatar
hmm guess i will have to check it out again and see if i mixed up the wire spot for the purple. thanks again shoebox
Nov 18, 2023 07:21 PM
lt1matt
Mar 21, 2015 07:35 PM
robcarnut
Mar 20, 2015 03:40 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
Jeff1904
Jan 3, 2015 12:00 AM
