Installed new MSD opti...still not start!
A little background:
I cleaned up my stock opti and put the rotor on a couple weeks ago. I had checked the fuel pressure before reinstalling the opti and it read 43# and held steady. The car ran well for about 4 miles and then when I mashed it to the floor and hit 6000rpm the engine died. I found a blown Ignition fuse. And I also found oil in the opti due to bad o-rings. I replaced the fuse and replaced the opti with a new MSD unit and replaced the coil. Put the car back together and now it still will not start, but I have NO FUEL PRESSURE. zero pounds on the guage and the fuel pump can not be heard running when I turn the key forward.
When the ignition fuse shorted, is it possible something else did too? Does anyone know what the fuel pump is tied into? I do not see a "fuel pump" fuse.
Re: Installed new MSD opti...still not start!
From shoebox' site:
http://shbox.com/1/fuel_pump_relay.jpg
Okay, I got it out but do not know how to tell if it is bad or not. Anyone know how to diagnose a bad relay? Also, is this something I will have to order through GM?
Originally Posted by seawolf06
Or just use one of the other relays in it's place, like the AIR relay since that won't do anything but maybe throw a code.
Originally Posted by mkent
That's not going to work since none of them are the same part number as the fuel pump relay.
Originally Posted by Dave89IROC
AIR pump relay will work, no problem, it is wired the same, just won't clip to the plug
I have an ohm meter, but can not find my test light. There are 6 wires which go to the fuel pump relay (green, black, grey yellow, red and orange).
Obviously black is ground. The grey is ground. I assume orange is prime, yellow is car running, and have no idea what green would be. What do I need to check with my ohm meter?
