Installed Height?
Old Jan 31, 2006 | 01:08 PM
"White Knight"'s Avatar
Installed Height?
So LT4 valve springs are speced at 1.75 installed height I believe. Now if I was to use these in my motor--which i plan to do, stock LT1 cam with 1.6 rockers I could decrease the installed height (for example 1.70) a little bit to gain a little more pressure.
What is the spec for the stock LT1 cam? I just need to find what lift I would have with 1.6 rockers and stock cam, then i could bump the installed height down, so I would be using more of the springs pressure.
Would this work? Disadvantages?, Advantages?
Or is this just absolutely stupid idea?
Old Jan 31, 2006 | 01:12 PM
Re: Installed Height?
As or right now I am just checking spring pressures before install them.
What is the lift of the stock LT1 cam?
Old Jan 31, 2006 | 01:18 PM
Stoopalini's Avatar
The stock cam has a lift of .298i/.306e. So with 1.6 rocker ratio, you get .477 and .490 on the stock cam.
With a 1.70 install height, and a .490 max lift, you get 1.21 max compression on the spring. Do you know the LT4 spring specs? (bind number, seat pressure @ 1.75, spring rate)
Thomas.
Old Jan 31, 2006 | 02:49 PM
1racerdude's Avatar
Ya won't see any "gains" from making the installed height shorter. Put them in at stock height and make sure ya use the LT4 retainers and keepers. I didn't and it cost me an engine.
Old Jan 31, 2006 | 02:55 PM
What happened? A keeper fall off??
Yea am using LT4 springs/retaineers/keepers the whole set.
Thomas.
So I should set it up @ 1.75 installed height? So extra seat pressure won't help at high rpms?
Old Jan 31, 2006 | 03:09 PM
1racerdude's Avatar
No the stock retainer folded up @6000.
Extra seat pressure in your set up won't help. Now if ya had a 230/240@50 cam ya would want to go up on the pressure because of the ramp speed so ya could control the valve. Stock cam, no help.
Old Feb 1, 2006 | 11:29 AM
Alright thanks. So stock installed height is 1.750" right?
Nov 18, 2023 07:21 PM
Victor Lamb
Aug 26, 2017 02:52 PM
1996LT1Z28
Apr 14, 2015 07:15 PM
Carogna'sZ-28
Feb 3, 2015 07:04 PM
cmdeshon
Dec 12, 2014 10:51 PM
