installed h/c running terrible...
Old Mar 19, 2005 | 05:17 PM
ajschult's Avatar
I just got done installing my LE3 package and upon starting the car up its running very rough. I'm pretty sure one cylinder isnt firing because it backfires at even intervals. Does anyone have any suggestions???
Old Mar 19, 2005 | 05:46 PM
97s10ondubs's Avatar
Re: installed h/c running terrible...
check all your wiring, you positive the timing chain wasnt a tooth off?
Old Mar 19, 2005 | 06:43 PM
SPEED750's Avatar
Double check the plug wires, you might have 2 crossed. If it's popping out the intake you might have the rockers to tight.
Old Mar 19, 2005 | 08:08 PM
NightTrain66's Avatar
I see that you got the cam in,
Make sure and adjust the rocker 1/16 of a tuirn past zero lash. Just enough to keep em quiet. The rockers being too tight or cossed plug wire are the 2 most common things. Hopefully this straitens it out.
Make sure you have all wires/sensors plugged in correctly and nothing unplugged.
Do you have some type of tuning done?
Lloyd Elliott
972-617-5671
Eportworks.com
Old Mar 20, 2005 | 08:14 AM
ajschult's Avatar
Lloyd Elliott
972-617-5671
Eportworks.com
The rockers were ticking a bit, so we loosened them up and now they dont make any noise. Will check the plug wires now, I got an email tune from ion. I read a post last night that sounded very similar to mine and he was a tooth off on the timing. Would timing being off a tooth do this?
Old Mar 20, 2005 | 10:19 AM
^ it could do it, thats why i asked
Old Mar 20, 2005 | 11:45 AM
ajschult's Avatar
The dots appear to be perfectly ligned up... we checked the continuity of the plug wires and all are good. I've checked over everything multiple times to see if there is some wires not connected but see nothing. We are completely stumped here.
Old Mar 20, 2005 | 04:52 PM
you said the rockers were ticking and you loosened them up and they stopped making noise?
Old Mar 20, 2005 | 06:05 PM
SStrokerAce's Avatar
Only way to tell if a cam is in correctly is to degree the thing in. The LE3 will have somewhat of a rough idle, but a missfire or having it installed wrong will really screw it all up.
Bret
Old Mar 20, 2005 | 09:03 PM
ajschult's Avatar
Yeah, I never actually heard any noise from them, but my brother said he did. Im sure they were too tight and may still be, we're going to try to readjust them again tomorrow.
Old Mar 20, 2005 | 09:05 PM
ajschult's Avatar
Bret
How do you degree it? What may we have done wrong if its installed incorrectly?
Old Mar 20, 2005 | 09:57 PM
You get a degree wheel kit.
I'm actually going to pick one up as a loner for customers so they can install the thing correctly to make sure everything is right.
Bret
Old Mar 21, 2005 | 03:04 PM
hey stroker, i didnt degree my cam in because it seemed from reading the threads on here that you would have to change your whole timing curve. Could this be causing my power issue? The car runs fine it seems, just has no power.
Old Mar 21, 2005 | 06:17 PM
Well degreeing it in is so you make sure it's installed straight up. I grind all my cams with the advance in them (if there is) so you install them straight up. Sometimes you can install the thing straight up and it comes out wrong. I'm having one of these fun times right now.
bret
Old Mar 21, 2005 | 06:59 PM
yea you did the cam for lloyd right, thats whats in my car, im gonna get it on a dyno and try to get ion to re-tune it to see if thats the prob
