install help
Old Sep 8, 2005 | 03:32 PM
LT193's Avatar
install help
Just got that Ac pulley delete PN NAL-10115875 from summit, its not as large as the ac pulley for the compressor. I was wondering how to install it, it kinda looks like a small tensioner, it has 3 bolt holes aswell. Just wondering, thanks for the pn shoebox ;]
Old Sep 8, 2005 | 04:15 PM
2000GTP's Avatar
Re: install help
Is it specific to an LT-1 motor? If the pulley is visibly smaller, then you are going to run into belt size issues.
Old Sep 8, 2005 | 04:20 PM
sssalah's Avatar
Re: install help
This is specific for the LT1 and comes stock on the earlier 1LE cars. The pulley on that bracket is smaller but it's also sort of shifted to the left. It bolts in place of the AC compressor on the accessory bracket using the same 3 bolts for the compressor.
Old Sep 8, 2005 | 04:23 PM
93black-ta's Avatar
Re: install help
simply remove the a/c compressor and bolt the pulley in its place. most people say they use a shorter belt with this pulley.
Re: install help
It's just an idler pulley. It may be a different size because there were two different size a/c pulleys used over the years. You may need to resize your belt. Don't ask me what size you need.
Old Sep 9, 2005 | 09:41 AM
LT193's Avatar
Re: install help
aight, thanks guys!
Nov 18, 2023 07:21 PM
Victor Lamb
Aug 26, 2017 02:52 PM
Richardan15
May 30, 2015 08:36 AM
1996LT1Z28
Apr 14, 2015 07:15 PM
Carogna'sZ-28
Feb 3, 2015 07:04 PM
