install on bmr struttower brace???
Old Apr 3, 2003 | 01:05 PM
Ben Ramsden's Avatar
hey folks, I have a bmr 2 point strut tower brace that I want to install, should I have the car on jack stands when installing, or on the ground. My guess would be on the ground, but wanted to double check?
Old Apr 3, 2003 | 01:19 PM
GREGG 97Z's Avatar
No need to put it on jack stands unless you just like it up higher to work on.
Eddie95Z28's Avatar
No no no, you should have it on level ground. so the suspension is properly loaded.
Old Apr 3, 2003 | 01:24 PM
I figured I should have it on the ground for that exact reason Eddie95Z28, but thought I would check in first. Thanks for the replies guys.
Ben
Old Apr 3, 2003 | 01:25 PM
GREGG 97Z's Avatar
Hhmmm, I did not know that. I assumed since it only goes on one way it didn't matter. I bought mine used though and didn't get any instructions with it but it seemed pretty straightforward. Anyway, I installed mine on the ground.
Old Apr 3, 2003 | 02:39 PM
chesee48's Avatar
Yea its a pretty striaght foward install....
Old Apr 3, 2003 | 02:54 PM
Calli's Avatar
so if i parked in the grass when i installed mine... is that bad ?
Old Apr 3, 2003 | 06:10 PM
BigEvil's Avatar
Did mine in the driveway, the grass probably wouldn't be any different. It's not like you're gonna be under the car.
Old Apr 3, 2003 | 08:18 PM
Calli's Avatar
i didnt know if the ground being uneven made a difference....
Nov 18, 2023 07:21 PM
HarleyZ28
Oct 5, 2015 06:23 AM
Richardan15
May 30, 2015 08:36 AM
Fusion93Z
Sep 10, 2002 06:46 PM
