injectors not pulsing
posting this for a friend with a 95 Z28...
he tested his injectors last night and found 3 of them are getting no pulse. what can cause this? where should he go from here to fix the problem?
Did he verify that he has +12V to the pink wire on each injector connector, when the key is "on"? There are 2 fuses that each supply +12V to 4 injectors. The PCM simply supplies the "ground" to complete the circuit and pulse the injector. If its got +12V, then he needs to check the resistance on each injector.... 12-15 ohms. If he's got good injectors, it will then point to a problem with the drivers in the PCM.
autoxr166
Sep 25, 2015 04:21 PM
