Injectors 24pd Can I Use In Stock 93
Re: Injectors 24pd Can I Use In Stock 93
24's will work but you'll have to change your tune so the computer knows you have 24's in there. You can find 24# SVO injectors all over ebay. New and used and the 24's are pretty reasonable in price.
Ken R.
Ken R.
The problem is that the ECM long term fuel corrections can only pull 15% maximum fuel. That means you are using most of that capability up with the oversize injectors, and the ECM is going to run into a brick wall when the long terms reach 108. Then it will have to rely on the short terms, which is not a good idea.
All that applies to closed loop, part throttle/part load operation. When you go into power enrichment mode (=~ WTO) since the long terms were cutting fuel in closed loop, the ECM will default to Cell 18, or as a minimum lock the Cell 15 long terms at 128, and you will be running 10-15% rich.
I love it when you talk dirty.
10-31-2016 11:09 AM
stockssn2o
05-25-2015 08:54 AM
