injector question??
Old Apr 23, 2003 | 04:55 PM
ram air camaro's Avatar
injector question??
i'm kind of concerned on my injectors because i have 157,000 miles on my car and injectors are still the stock ones do you guys think i will feel a difference if i replace them, i have a bad throttle response when the last gear hits at about 45 mph in cruising speeds, i'm guessing that might be the problem what do you guys think?? give a hand here yeah?
Old Apr 23, 2003 | 11:37 PM
TTT
Old Apr 23, 2003 | 11:47 PM
I would not replace injectors without some sort of test that indicated one was bad. There are so many other things that could be your problem. Any ignition stuff, fuel pressure ( a fuel filter would be a good thing to replace if it has been neglected) . Perhaps if you could have it run with a scanner to see if something obvious shows up.
Old Apr 23, 2003 | 11:52 PM
chasmanz28's Avatar
yeah man go with the simple things first, least expensive to if that doesnt work go to auto zone and get yr car scanned for codes
Old Apr 24, 2003 | 12:20 AM
no scanner seems to detect anything in my car for some odd reason i replaced the fuel filter though how would i go on checking the injectors is there some machine?
Old Apr 24, 2003 | 12:35 AM
LPEdave's Avatar
Re: injector question??
Originally posted by ram air camaro
... i have a bad throttle response when the last gear hits at about 45 mph in cruising speeds
What does this mean? What gear are you in, automatic or manual? What RPM is this at? It kind of sounds like you're saying that in overdrive at 45mph, you have bad throttle response. I think we all do....
Dave
Old Apr 24, 2003 | 12:43 AM
yeah in overdrive i have an a-4
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
LT14LIFE
Feb 9, 2015 09:35 PM
nophix
Nov 30, 2014 10:26 PM
Jul 4, 2005 05:00 PM
