weird crank
Old Apr 23, 2003 | 09:42 PM
96illusionbird's Avatar
weird crank
so when I put my new starter in and tried to turn the car over. It tries and then stops and loses power. The current draw to the starter is fine, the ground is fine.
Could the timing be off???? Or the opti pin not be seated correctly? It's a 94, instead of the 96 that my user ID says.
Thanks.
Old Apr 23, 2003 | 11:03 PM
Depends. Did you do something more than just put a starter in? Is there more to the story?
Old Apr 23, 2003 | 11:15 PM
yeah sorry, it's been a total strip down of the front of the motor. It ran before I had to replace the water pump driveshaft, opti, starter, and ignition module. Replaced all of that and put it back together.
Old Apr 23, 2003 | 11:24 PM
If special care was not taken to orient the opti, then I would say it was a suspect. Another very common mistake is that the spark plug wires are not in the correct position. Make sure your battery cables are tight, also.
Old Apr 24, 2003 | 12:45 AM
wires on the opti are right
battery cables are tight.
Will check the opti for sure
AviatorDave
Dec 19, 2016 06:35 PM
jbert55
Oct 31, 2015 03:52 PM
truthmatters
3rd Gen / L98 Engine Tech
Aug 19, 2015 04:09 PM
4586
Aug 18, 2015 07:08 AM
Catmaigne
Jul 14, 2015 05:17 PM
