Which injector?
Which injector?
Putting a suport mod parts list together for me LE2 setup. Heres what I plan on so far...
58MM (deciding on BBK or Holley) TB
Hooker Super Comp LT's
Hooker Y-Pipe
Hooker Cat-back
EGR block plate
O2 extentions
LT4 timing chain
Next thing to decide on is injectors. Don't know much about the different brands. I guess my main 2 choices are 30lb. Accel from Summit ($259.95) or 32lb. Delphi/Lucas from Racetronix ($254.92). Anyone have any thoughts on either? How about Delphi's disk design or whatever. Like I said, I don't know too much about the different brands. Any suggestions? Other brands maybe?
Hooker Y-Pipe
Hooker Cat-back
EGR block plate
O2 extentions
LT4 timing chain
Re: Which injector?
That was my first guess about the accel's, but only based on their plug wires. I wasn't sure if the injectors were the same quality stuff. I was thinking Lucas anyway. Thanks. Any other ideas anyone?
Re: Which injector?
I know im plenty pleased so far with my SVO's. I haven't gotten into the motor yet to truely benefit from them, but I noticed a slight difference in drivability when switching to them from my stockers but the stockers were pretty gunked up and worn. Plus I had the ecm tuned when I put them in so that probably has alot to do with that as well. Pretty easy install once I got the junk stockers unseated. The SVO's slid right into place almost too easy.
autoxr166
Sep 25, 2015 04:21 PM
