Initial thoughts on GM 847
Old Apr 18, 2004 | 03:48 AM
97bowtie's Avatar
I just finished up the install last night and the car runs great.
For those of you who don't know, I had been running a CC305 for the past couple years and the car ran the numbers in the sig on stock heads. I recently purchased an '00 SS as my daily driver and now the '97 gets all the 'race car' duties. :P
The car pulls MUCH harder up top than the CC305 did. The 305 would fall off around 57-5800 RPMs where as the 847 is just getting started at this point. The SOTP gain is awesome and I don't think the car will have any trouble trapping in the 113-115 range.
As far as driveability, the cam drives great. Hardly any difference between this cam and the CC305 as far as cam surge goes. The cam is very tame even in 6th gear at ~ 55 mph (13-1400 RPMs).
Overall, I think it was a good switch. The power is awesome. I'll have new track times this coming Friday.
Old Apr 18, 2004 | 07:58 AM
SLeePer350's Avatar
hey, where was the main difference vs. your 305 cam?? through the whole rpm range or just up high?
i am considering doing a switch from my tpis zz9 cam which is only 212/226 (similar to hotcam) to something more radical, like a 227/233 or even 230/236. i think the gm847 may be too big for my setup, mainly because it would be better suited for a 383 stroker imo, but you get the idea....
the difference between the 305 and your 847 is probably not as much as my tpis to the 847, i still want to know for sake of comparison..
streetability? which springs did you end up going with??? dyno?
thanks
Old Apr 18, 2004 | 04:34 PM
97bowtie's Avatar
The 847 seems to make more power everywhere - not just up top. The streetability is just as good as the 305. I was expecting to see a lot of cam surge with the 847, but the surge is very minimal.
I haven't dynoed the car w/the new cam but I will have track/dyno numbers very soon.
I went with the K-Motion K-800 springs - they are good to .700" lift and don't require any machining.
Old Apr 18, 2004 | 04:55 PM
SLeePer350's Avatar
how much were you k-motion springs, and where from??
Old Apr 18, 2004 | 10:40 PM
AdamZ1LE28's Avatar
yes i'd like to know this too
Old Apr 18, 2004 | 10:43 PM
97bowtie's Avatar
The springs were $90 from Summit.
Old Apr 19, 2004 | 02:55 AM
SLeePer350's Avatar
this may be a dumb question but can those springs be used with a slightly smaller cam such as a 230/236 xe??? or are there springs that are better suited for a cam like that, if so, which ones?
thanks
Old Apr 19, 2004 | 11:05 AM
supermaxxbasher's Avatar
where can I find a GM 847 cam at?
Old Apr 19, 2004 | 11:11 AM
badblackta's Avatar
Scoggin-dickey parts center. SDPC2000.com
Old Apr 19, 2004 | 12:17 PM
Gripenfelter's Avatar
The GM 847 is a pretty big cam. You should do gears/high stall with it for sure.
Old Apr 20, 2004 | 06:48 AM
RealQuick's Avatar
Re: Initial thoughts on GM 847
Congrats dude. I always enjoyed watching your vids that you posted. Go get that ZO6 you raced before
brothaslide
Jan 9, 2016 12:11 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
KYWes
Aug 10, 2015 07:03 PM
colts0455
13
Aug 7, 2015 09:15 PM
techstar
Aug 6, 2015 11:20 AM
