Info needed on exhaust and Y pipe, Please Help
Old Feb 28, 2005 | 01:55 PM
keng's Avatar
I have decided on a loud mouth exhaust for my 97 camaro, which Y-pipe do I need to or which one will work with this exhaust? Also do I need o2 extenders?
Old Feb 28, 2005 | 01:58 PM
TheBiz's Avatar
Re: Info needed on exhaust and Y pipe, Please Help
Do you have headers? If not it should bolt right up with the stock y-pipe. If you have headers, then you will need the corresponding y-pipe. Whether or not you have long tube headers will determine if you need O2 extenders.
Old Feb 28, 2005 | 02:31 PM
keng's Avatar
I want to use a after market Y pipewith this exhaust, still not sure if i will go with shorty or Long lubes, but which Y pipe will work with long tubes or shortys?
Old Feb 28, 2005 | 03:03 PM
TheBiz's Avatar
They are each going to have there own y-pipes. If you get shorty headers there will be a small selection of pipes that go with those, and vise versa. If you want to keep from buying 2 different y=pipes when you decide whic headers you want, I would go with an SLP y-pipe that will work with stock manifolds and shorty headers.
You won't get the power out of shorties like you would long-tubes, but if you are looking to buy one y-pipe, you will have to go with shorties. Any of these places will have y-pipes that you can choose from.
www.thunderracing.com
www.slponline.com
www.tbyrne.com
etc.
Good luck, I hope I helped and wasn't rambling.
Old Feb 28, 2005 | 05:29 PM
keng's Avatar
www.slponline.com
www.tbyrne.com
etc.
No dude, you were not rambling, I was taking in your advice in input.
I have the loud mouth cat back, I want to go with long tubes, but am afraid they will make it hard to change spark plugs, also I am told they are a pain to install.
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
MadMav
Feb 6, 2015 11:02 PM
Jan 5, 2015 07:14 PM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
