Independent Rear suspension on fbody
Old Nov 16, 2003 | 12:53 AM
TechnoThief's Avatar
Has anyone ever converted the rear suspension on an fbody to independent rear suspension? If it has been done, how is the handling?
Old Nov 16, 2003 | 02:52 AM
Ws6Envy's Avatar
few have done it....not impressive results for the mad $$$ spent. instead of idependent rear end, buy sway bars and adjustable shocks, and lower control arms and a strut tower brace. You can get all the about suspension items for 1300 which is basically 1/2 the cost of the independent rear end conversion with 10 times the results
Old Nov 16, 2003 | 05:23 AM
97WS6SCharged's Avatar
Yeah, the f-bodies weren't designed for IRS. Don't get me wrong, it's got a huge cool factor, but do you really need it? Answer... no. If you want IRS, get a Vette. If you want your f-body to handle well, just get a good rearend and some good suspension parts. At least with a 12 bolt or a 9 inch, you won't have to worry about breaking half shafts.
Old Nov 16, 2003 | 09:41 AM
grendal's Avatar
Waste of $$$... Never seen one myself, but the ONLY place where IRS has an advantage over a solid axle is on rough and uneven surfaces.... Otherwise, the solid axle is on-par, if not faster in many cases when setup properly.... This means not-stock.
-Michael
Old Nov 16, 2003 | 09:55 AM
Steve0's Avatar
Someone in the autocross section was guaging interest for the design of a IRS kit not too long ago. You might want to check in that section.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
94z28jbw
Sep 8, 2002 03:22 PM
guionM
18
Jul 23, 2002 04:24 AM
