impy head gasket
Old Dec 31, 2003 | 12:48 PM
Quick96Z's Avatar
impy head gasket
This is a question i have always had ....when you go to .029" impala head gaskets, do you have to get different lengthed pushrods to compensate for the slightly smaller head gasket? Or is it such a small difference that stock length pushrods would work fine?
I understand that the impy head gasket is an easy way to up the DCR, and with a 160* thermo, an aluminum headed LT-1 should be fine with it, right?
thanks
trav
Old Dec 31, 2003 | 12:53 PM
Mike383LT1's Avatar
head gasket
no you do not need a longer pushrod to compensate for the smaller head gasket
Old Dec 31, 2003 | 08:49 PM
Josh-'04 GTO's Avatar
Re: impy head gasket
As Mike stated, stock pushrod length is fine if Impy head gasket is the only change to valvetrain geometry.
Old Jan 31, 2004 | 08:24 PM
1FASASZ's Avatar
how about with a 20 thousands mill?
Old Feb 1, 2004 | 01:35 AM
hvyss's Avatar
If you only put on the Impala gasket the pushrods will work fine. If you mill the heads then go to a shorter pushrod. I had my AFR's redone and the machine shop milled them .003 to true them. I asked if I needed to go to shorter pushrods and was told unless you mill .010 or more the stock pushrods will work fine. This is what I was told. Other people may have a different opinion on this and please weigh in. Good luck!
HVY SS
Old Feb 1, 2004 | 06:33 AM
RE AND CHERYL's Avatar
I would assemble the valve train and check the contact patern to see for yourself. My guess is you would be right on the edge of needing new pushrods.
Old Feb 3, 2004 | 10:46 AM
SVT Killer LV's Avatar
I milled my heads much more than that and I went with the Felpro HG's, I used a pushrod checker and mine are fine.
Old Feb 3, 2004 | 10:50 AM
WS Sick's Avatar
Usually on a Hydraulic valvetrain a small change in deck height will be compensated for by the lifter. but if you combined all that with say taller valves and milling a different size would definately be needed. I have also seen good contact paterns on a stock setup with .100 shorter pushtubes and an impy gasket.
Old Feb 3, 2004 | 12:47 PM
Zachz28's Avatar
Someing to think about
Impy heads are cast iron right? Well this means that the gasket is desigened to be betwen 2 similar metals with similar exapinon rates. But F-body LT1s have alummiun heads which exapand at a different rate so F-body head gaskets can't be alowed to "stick" to the block or the heads because they will be pulled apart by the other metal exapanding differently Impy's LT1s dont do this. I would think.
Old Feb 3, 2004 | 01:00 PM
WS Sick's Avatar
The impy gasket is an embossed steel shim, which expands and contracts differently than iron does.
I ran impy gaskets on my 93 for years with no problems.
The Felpro is a coated composit material as well as the stocker.
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
